I am getting below error while syncing,Using version 11.27
Cannot Copy File
ERROR_FILE_EXISTS:The file Exists.[CopyFileEx]
ERROR_SHARING_VIOLATION:The process cannot access the file because its being used by another process[Delete File]
Cannot Copy File ERROR_FILE_EXISTS:The file Exists.[CopyFileEx]
What is the full error message (without alterations)?
Error: Cannot copy file
"C:\Evening_11PM\dmp_WED_PROD.log" to
"D:\DataBase_BACKUP\Evening_11PM\dmp_WED_PROD~97c3.ffs_tmp".
ERROR_FILE_EXISTS: The file exists. [CopyFileEx]
Cannot delete file "D:\Evening_11PM\dmpPROD~97c3.ffs_tmp".
ERROR_SHARING_VIOLATION: The process cannot access the file because it is being used by another process. [DeleteFile]
You can use copy and paste to insert the error message here. No need to type manually.
These are two error messages. I'm assuming they are from different sync runds.
No locking process for ERROR_SHARING_VIOLATION is shown. Therefore most likely something on D:\DataBase_BACKUP is locking, assuming it is a network drive.
The ERROR_FILE_EXISTS doesn't make sense, unless it's similar/identical to viewtopic.php?t=7898
