Automatic Folder Monitoring & Syncing?
muzicman82
Are there any features currently available or plans to have FFS monitor a local Windows folder and automatically sync changes to multiple SFTP folders? Similar to Dropbox or Google Drive?
muzicman82
Good stuff! Anything I should be aware of?
So if I specify a ffs_batch file, the real time sync will do exactly the same as the GUI including ignoring excludes and doing sync the same method as the preset (like Mirror instead of Two-Way)?
