I consistently get an error that causes my update to hang for about 10 minutes:
"ERROR_CRC: Data error (cyclic redundancy check). [CopyFileEx]"
I don't care about this one file (of 50,000) in my update. I have been able to con tinue after the 10-minute hang.
Is there some way to set "ignore all errors" *before* I start the Update?
OR is the amount of time spent attempting any single file configurable (such as 1 minute)?
Thanks.
CRC error (CopyFileEx) causes 10 minute hang
If it is always the same file causing issues, and (as you write) you don't care about this one file, you can use the FFS Exclude Filter to exclude said file from your sync.
The filter solution worked like a charm! Thank you so much!If it is always the same file causing issues, and (as you write) you don't care about this one file, you can use the FFS Exclude Filter to exclude said file from your sync. Plerry, 11 Dec 2022, 15:44
