Hi guys, love the work you are doing, please keep it up.
1. May I inquire if the feature below mentioned are already in the current version?
2. Can it also encrypt files and filenames like Cryptomator? Cryptomator is also opensource btw. If not, integration would be awesome.
(Wizard with checkbox "Open everytime app starts")
Mode 1 Basic
No Frills Usage, just backup from a to b.
Mode 2 Intermediate
Includes Authentication/Encryption etc
Mode 3 Advanced
Configure Active-Workspace, Cache, Archive
Active-Workspace: is how much space intended for use to sync between "a" & "b", cannot be beyond free space of physical drive. Because obviously cloud space can be bigger than local hard-disk. And at any particular time only a certain amount of data is required and not the entire volume.
Cache: is space in the physical drive that is set aside so that exploration and retrieval of data from archive to Active-Workspace can be accommodated.
Archived: are files on "b" or storage/cloud, which are not meant to be synced on to local computer. This way, files meant to be archived will not occupy unnecessary local disk storage.
Thank you!
-AOS.
Modes
None of that is supported as explained. There are filters which may be used to achieve some similar results though
Hi xCSxXenon,None of that is supported as explained. There are filters which may be used to achieve some similar results though xCSxXenon, 20 Dec 2022, 15:16
1. Where is it explained?
2. Which filters are they?
-AOS.
1) I mean the things you explained are not supported
2) Filters: https://freefilesync.org/manual.php?topic=exclude-files
Are these constructive suggestions that can improve the application? Where in this forum should I post these suggestions so the dev could see this?1) I mean the things you explained are not supported
2) Filters: https://freefilesync.org/manual.php?topic=exclude-files xCSxXenon, 20 Dec 2022, 16:50
-AOS.
