MacOS Ventura: Installation failed
Aladin1111
Hi everyone. I had installed v 11.28 on the latest MacOS Ventura and I wanted to upgrade to 11.29 today. I've got an installation failed error and I also can't install any previous versions. I have saved an old 11.25 version from a couple of weeks ago and with that I have no errors. Any ideas?
Aladin1111
I tested this on another Mac and it was the same problem. No one else with this problem?
Aladin1111
Hello everyone. Is no one experiencing an installation problem like I have on 2 different MacBooks with Ventura?
Aladin1111
I just found the solution for this. I dragged the installer pkg from the downloads folder to the desktop.
einarenrique
WOW it works, thanks!
I believe there was a popup dialog asking "Do you want to grant FreeFileSync access to the Downloads folder", that you declined?
