Hello together.
How can I disable in Freefilesync to sync file JPG into the file -->
xxxxxx.photoslibrary.
Is ist possible to sync the file xxxxxx.photoslibrary only komplete?
Mit freundlichen Grüßen
Jürgen
Disable xxxxxx.photoslibrary
(I'm not quite sure how filtering works, but...)
(And without reading, heh...)
https://freefilesync.org/manual.php?topic=exclude-files
Maybe something like, Exclude:
the "photolibrary" is not a file, it's a folder, so you may need to clarify or change what you are wanting to do
