I have a QNAP RAID array. I back up a lot of folders very successfully but, for one product called "CompanionLink" I get the messages:
00:46:12 Warning The following items have unresolved conflicts and will not be synchronized:
dejaoffice.db: Both sides have changed since last synchronization.
log.txt: Both sides have changed since last synchronization.
CompanionLink\ClxDate-dpc-5034b9a3-8392-4f94-9d9a-bd58f55933ab-device-.Dat: Both sides have changed since last synchronization. and similar.
I am synchronizing using "Update" with "File time and size" comparison and am using the latest version under Windows 10.
As I only use the RAID for backups then I cannot see why the application thinks that both sides have changed and only one set of files and folders.
If it did this for all of my backups I would be looking into the settings but it is only one particular baxckup which is strange.
Getting "Both Sides have changed" etc. for just one folder.
From the fair understanding of RAID that I have, the fact that you have your backup disks setup as a RIAD array should never cause the problem(s) you describe. RAID simply spreads your (unmodified) data across multiple disks, potentially, depending on the type of RAID (e.g. 0, 1 or 5) you use allowing one or more disks in your RAID set to fail without the loss of data.
I don't know CompanionLink/DejaOffice nor QNAP (although I know Synology).
But of these two, the cause of your problem almost certainly rests in CompanionLink/DejaOffice, not in your QNAP.
The simplest approach is likely to exclude said two files from your FFS sync using the Exclude Filter.
If you still want to make a backup of your CompanionLink/DejaOffice database and log files, you could
1)
try doing that separately (outside FFS) as described here and here.
Or 2)
In FFS, next to your present left-right pair you define an identical second left-right pair.
In your first left-right pair you now create a local Filter setting (via the icon mid between the left-right location) where add said two files to your Local Exclude Filter.
In your second left-right pair you create a local Include Filter in which you replace the default * (=everything) by said two files, and create local sync settings in which you select the Mirror sync variant (instead of Update). Make sure to select your left-side location to comprise the correct version of said two files, and you right-side location as your "backup" side.
1)
Or 2)
OK, I read your comprehensive reply and also looked at the underlying philosophy of FreeFileSync. I then took the following action.
I inspected both the source and destination folders to see if there were any significant problems with files, changes etc. Then I made a fresh copy on the target using copy. I then deleted the FFS database files and resynced. All is perfect now.
Something I do from time to time is trim the files on the NAS directly. As I tend to use update source->destination then older versions of files can accumulate. I delete them directly from the NAS and I think that this can upset the synchronization databases.
All sorted now so thanks for your help.
With a mix of Windows and Linux systems FFS is the only solution that really works for me which is why I continue to support this project.
Happy New Year!
Happy New Year!
