Hello. I'm using a 2019 Intel MacBook Pro running Sonoma 14.5 and FreeFileSync 13.7. I'll try to make this clear. I need to sync the contents of two external drives A and B.
Drive A contains files and folders not present on drive B.
Drive B contains files and folders not present on drive A.
I need to sync drives A and B resulting in the contents of both drives being identical, and no files are deleted from either drive. I'm trying to keep this simple. I need help on what options to choose in FreeFileSync to accomplish this. Thanks in advance for any advice you can provide.
Help Syncing Two External Drives on Mac
