Every time I add a directory to scan using the 'browse' option, FFS saves that directory for faster pullup in the future.
Let's say I want to clear that directory.
How can I do that? Couldn't find any way to do it.
How to clear the drop-down directory list
Got it, thanks!
And for any future readers: Use Mouse/hover and delete key.
You just move the mouse over the directly selection and then tap the delete key. Item should disappear, leaving a space in the list. And you can just slowly move the mouse up and down while spamming the delete key. And you have to do both left and right sides separately.
Worked for me on Win10. Whatever is the recent Home build on 2024.11.5. Supposedly there's issues with Linux and Mac, so YMMV there. Check the links in the reply for more.
