Updated this morning to Donation version 14.2. Every time I open the application I get this warning:
FreeFileSync Warning: gAMA: gamma value does not match sRGB
This warning has never happened before. I did not take a snapshot, so I cannot roll back this update.
I will not sync any files until I have an answer about what this error is and how to fix it.
Likewise, I will not update my other PCs until this issue is resolved on this machine.
Thank you, LC.
Warning? gAMA: gamma value does not match sRGB
I have the same problem
I can't attach the dump because it's too big...😢
Are you able to reproduce the crash consistently? Does the current beta version also crash?I have the same problem
I can't attach the dump because it's too big...😢 vika51, 03 Mar 2025, 10:15
https://www.mediafire.com/file/0ih2isrifm18ibf/FreeFileSync_14.3_%255BBeta%255D_Windows_Setup.exe
Hello Zenju
There is no more issue with the 14.3 beta.
It’s perfect
Thank you very much
Gérard / vika51
It’s perfect
Thank you very much
Gérard / vika51
As I expected. The crashes looked like a codegen bug.
Thank you for your responsiveness
Are you running 32-bit Windows?
"gAMA: gamma value does not match sRGB" could be related to:
viewtopic.php?t=12089
Yes, I am, however, I updated to 14.3 a few days ago, and the "gAMA: gamma value does not match sRGB" error was fixed, but now the progress display graphs no longer work.
I have reverted back to the 14.0 non-donor edition, which works fine on my ancient PC's. I will use this version from now on, and skip the updates.
What does this mean?but now the progress display graphs no longer work. lcampo, 03 Apr 2025, 19:04
The progress display window opens and it flashes momentarily. The progress window is then displayed as just a white block with some of the text at the bottom, but no X-Y progress % graphs that show how much time and data is remaining to be sync'd.
