Dear FreeFileSync Support,
I accidentally installed FreeFileSync on two devices (Imac en Android), even though my license allows usage on only one. The application indicates that I can’t remove a device until May 23, but I’ve already manually uninstalled FreeFileSync from one of the devices (an Android), including all associated support files.
Unfortunately, the software on my Imac still reports that it’s installed on two devices, preventing me from using it on my other computer. I would kindly like to ask if you could manually deregister or reset the license associated with the removed device.
Thank you very much for your help!
Best regards,
BME
Accidentalyy installed on 2 devices
my license allows usage on only one BME, 24 Apr 2025, 08:56
It seems you may be confusing Donation Edition and Business Edition. The Donation Edition your're using can be installed on more than one device:
https://freefilesync.org/faq.php#donation-editionThe FreeFileSync Donation Edition is expected to be used by you and your friends.
