300k files sometimes it scans them sometimes not
bogdandumitrescu
in a folder i have +300k files and sometimes when i synchronize it , it takes a minute or 2 , sometimes is like 30 seconds , and today is 1 second ... and no , i do not have the database enabled
I am guessing is doing some sort of file change monitoring somewhere ,
Is there a way to clear that cache or delete the file or reset it , to force it to rescan all the files ?
Is this causing an issue or you just don't like it?
bogdandumitrescu
it does not scan so it does not recognize changes to files , i need to restart the app
Even if you click the compare button again? Working fine for me
... i need to restart the appbogdandumitrescu, 23 Oct 2025, 23:59
It seems you run a sync in FreeFileSync (FFS) and after the sync has finished leave that FFS instance open and then expect FFS to continue keeping both sides in sync.
That is not the case. You need a renewed Compare before running a renewed sync.
If you left the FFS app open, then, as xCSxXenon wrote, you need to click Compare manually.
If you closed the FFS app and open it again, a Compare is always performed , whether you click Compare or directly Synchronize.
FFS does not continuously monitor for changes.
That is what RealTimeSync (RTS), that comes with FFS, is for. RTS monitors for changes in specified folders (and their subfolders) and upon detecting any such changes launches FFS to run a specified sync.
bogdandumitrescu
Sorry.... When i said Sync ....i meant click on Compare... My bad
So i click on compare take a minute
I sync
Then an hour later i click on compare and in 1 second is ready
