Macos Automator
richard49
As a 'newbie' here I saw a video which implied that I could use macOS Automator to automatically sync files whenever there's a change on the source drive.
Is that correct and if so how would I make this work; I've only just downloaded FreeFileSync and have never used Automator.
Any advice/help would be very welcomed as I can't find a video explaining it.
Thanks,
Richard
https://freefilesync.org/manual.php?topic=realtimesync
Save an RTS configuration and configure it to start automatically upon logging in
richard49
Sorry to come across as thick but I've looked at the page concerned with regard to ReelTimeSync and can't find a file to download to use on my Mac or do I have to write the file myself?
Is there a simple guide/video clip showing me what to do being new to Mac and File Sync?
https://freefilesync.org/tutorials.php (the bottom-left video)
And the earlier mentioned https://freefilesync.org/manual.php?topic=realtimesync
To automatically start a FreeFileSync (FFS) synchronization, see
https://freefilesync.org/manual.php?topic=schedule-batch-jobs#macos
To automatically start a RealTimeSync (RTS) job, act as per the link just above, but in step 7 do not drag and drop the *.ffs_batch FFS sync configuration file, but instead drag and drop your *.ffs_real RTS configuration file.
