Unable to use run files on the donation edition
sharlock
I have been trying to use the donation edition .run file and license file, but i cant even get the .run file to work
my ubuntu version is Ubuntu 24.04.3 LTS
I tried double clicking the file as well as executing this in terminal as well but none of it works
I am only able to see a proper error in the terminal which is
cannot execute binary file: Exec format error - without using sudo
or
Syntax error: ")" unexpected - with sudo
I tried everything i could but i'm new to linux and need your help
Did you extract the files out of the zip you downloaded?
sharlock
Yes, thats how i got the .run and license files
Try the free version of FFS just to see if this is a FFS issue or OS issue
sharlock
thats the other thing, i was able to install FFS using apt--get install, but i couldnt use the downloaded file, even for the free version. I got the same error then too
What CPU? Sounds like an architecture mismatch. FFS doesn't have ARM support in Linux AFAIK
sharlock
Oh, i run ubuntu on a Raspberry Pi 5
So, FFS wont work on it if i install it using a run file?
It works fine when i use apt-get install though
Someone is taking the source code of the free version and compiling it for ARM.
viewtopic.php?t=12551
viewtopic.php?t=9848
sharlock
Oh, then I'm at a loss
Thanks for the help
