Errors and warnings:
10:54:48 AM Warning: Cannot write modification time of "mtp:\DS Galaxy A35 5G\SD card\Music1\Derek Sherinian\2022 - Vortex\01 - The Vortex-00ab.ffs_tmp".
Setting the modification time (6/15/2026 09:45:26 PM) was silently ignored by the device (6/16/2026 10:54:48 AM).
10:54:50 AM Warning: Cannot write modification time of "mtp:\DS Galaxy A35 5G\SD card\Music1\Derek Sherinian\2022 - Vortex\02 - Fire Horse-3b5c.ffs_tmp".
Setting the modification time (6/15/2026 09:45:26 PM) was silently ignored by the device (6/16/2026 10:54:50 AM).
10:54:51 AM Warning: Cannot write modification time of "mtp:\DS Galaxy A35 5G\SD card\Music1\Derek Sherinian\2022 - Vortex\03 - Scorpion-4f16.ffs_tmp".
Setting the modification time (6/15/2026 09:45:26 PM) was silently ignored by the device (6/16/2026 10:54:51 AM).
10:54:52 AM Warning: Cannot write modification time of "mtp:\DS Galaxy A35 5G\SD card\Music1\Derek Sherinian\2022 - Vortex\04 - Seven Seas-f243.ffs_tmp".
Setting the modification time (6/15/2026 09:45:26 PM) was silently ignored by the device (6/16/2026 10:54:52 AM).
10:54:53 AM Warning: Cannot write modification time of "mtp:\DS Galaxy A35 5G\SD card\Music1\Derek Sherinian\2022 - Vortex\05 - Key Lime Blues-a114.ffs_tmp".
Setting the modification time (6/15/2026 09:45:26 PM) was silently ignored by the device (6/16/2026 10:54:53 AM).
10:54:56 AM Warning: Cannot write modification time of "mtp:\DS Galaxy A35 5G\SD card\Music1\Derek Sherinian\2022 - Vortex\06 - Die Kobra-cf82.ffs_tmp".
Setting the modification time (6/15/2026 09:45:26 PM) was silently ignored by the device (6/16/2026 10:54:56 AM).
10:54:57 AM Warning: Cannot write modification time of "mtp:\DS Galaxy A35 5G\SD card\Music1\Derek Sherinian\2022 - Vortex\07 - Nomad's Land-e83c.ffs_tmp".
Setting the modification time (6/15/2026 09:45:26 PM) was silently ignored by the device (6/16/2026 10:54:57 AM).
10:55:00 AM Warning: Cannot write modification time of "mtp:\DS Galaxy A35 5G\SD card\Music1\Derek Sherinian\2022 - Vortex\08 - Aurora Australis-1e4b.ffs_tmp".
Setting the modification time (6/15/2026 09:45:26 PM) was silently ignored by the device (6/16/2026 10:55:00 AM).
10:55:01 AM Warning: Cannot write modification time of "mtp:\DS Galaxy A35 5G\SD card\Music1\Derek Sherinian\2022 - Vortex\Folder-7d3c.ffs_tmp".
Setting the modification time (6/15/2026 09:32:09 PM) was silently ignored by the device (6/16/2026 10:55:00 AM).
I only get this from the Samsung my Moto G power (backup phone) works for same files fine.
errors on sync Galaxy A35 and my PC windows 11
If you do a search in this forum on "Galaxy MTP" you find numerous posts on the same issue.
Particularly Samsung apparently severely messed up their MTP protocol implementation.
The general recommendation is to use FTP or SFTP instead of MTP.
Thanks. The files seem to play properly in PowerAMP on my phone. Do I need to go though the ftp process or are these benign errors?
I have a Galaxy cell phone and can confirm that FTP or SFTP are better choices than MTP. I use FTP to eliminate the encryption overhead because I'm working at home and don't worry about the encryption.
There are several applications that are in Google Play that provide FTP.
I recommend an app called Wi-Fi FTP server.
If you're an advanced user you can load termux and ftp. It will yield somewhat faster results but requires more technical skill and some Linux knowledge.
John1234,
Thanks for the tip! Wi-Fi FTP server worked perfectly I set it up to use FTPS with password and ID, even at home I like security. FreeFileSync connected to it via the the Access Online Storage synced my new tunes with no errors. Actually easier than the mtp connection just push a button on the app and ready to go. Thanks to all for being there!
Cool. Glad to assist. I do a lot of networking tech.
