Catalan translation
How can I help you to create the Catalan translation of FFS?
Cool! Just ping me shortly via email (see FFS's about dialog for the address) and I'll reply with all the details you'll need to know.
Hi Robert!
Unfortunately I'm not able to respond to your email, I'm getting the following error mail:
A message that you sent could not be delivered to one or more of
its recipients. This is a permanent error. The following address
failed:
SMTP error from remote server after RCPT command:
5.7.1 Service unavailable; Client host [212.227.15.19] blocked using bl.spamcop.net; Blocked - see http://www.spamcop.net/bl.shtml?212.227.15.19
failed:
Hi Zenju,
Is there any update about this translation? Any chance I can help?
I've forwarded your request to two people how are currently working on Catalan. Thank you!Hi Zenju,
Is there any update about this translation? Any chance I can help?ngoula
Hi FreeFileSync Team,
I translate FFS to Catalan Language and attached here catalan.lng into ZIP file.
Please, release it.
Thanks and enjoy!
Please, release it.
Thanks and enjoy!
FFS translated into Catalan for version 9.8.
Attached below catalan.lng file in a ZIP.
Thanks and enjoy!
Thanks and enjoy!
FFS translated into Catalan for version 10.0.
Thanks and enjoy!
Thanks and enjoy!
Hi everybody,
Translation of FFS v10.0 into Catalan works good on FFS V10.1
Thank you and enjoy it.
FFS translated into Catalan for version 10.2.
Attached below catalan.lng file in a RAR.
Thanks and enjoy!
Thanks and enjoy!
FFS translated into Catalan for version 10.3.
Thanks and enjoy!
Thanks and enjoy!
FFS translated into Catalan for version 10.4 and 10.5.
Thanks and enjoy!
Thanks and enjoy!
FFS translated into Catalan for version 10.6
Thanks and enjoy!
Thanks and enjoy!
FFS translated into Catalan for version 10.8
Thanks and enjoy!
Thanks and enjoy!
FFS translated into Catalan for version 10.10
Thanks and enjoy!
Thanks and enjoy!
FFS translated into Catalan for version 10.12
Thanks and enjoy!
Thanks and enjoy!
Hi everybody,
Translation of FFS v10.12 into Catalan works good on FFS V10.13
Gràcies
Gracias
Gracias
Així és més agradable treballar.
That's so nice to work.
Hi everybody,
Translation of FFS v10.12 into Catalan works good on FFS V10.14
I send icons.zip with the new flag of the Catalan language.
Betulo, thank you for the "estelada".
FFS translated into Catalan for version 10.15
Thanks and enjoy!
Thanks and enjoy!
FFS translated into Catalan for version 10.17
Thanks and enjoy!
Thanks and enjoy!
Hi everybody,
Translation of FFS v10.17 into Catalan works good on FFS V10.18, V10.19 and V10.20
FFS translated into Catalan for versions 10.25 and 11.00
Attached below catalan10-25.lng and catalan11-0.lng file in a RAR.
Choose the file that suits you.
Thanks and enjoy!
Thanks and enjoy!
And happy new year 2021 🎊
FFS translated into Catalan for version 11.5
Thanks and enjoy!
Thanks and enjoy!
You're awesome for keeping up with this!
Why the application does not show Catalan as language if it is translated?
Flag of Catalonia (if there is any doubt): https://en.wikipedia.org/wiki/Senyera
Thank you in advance
It's likely that Zenju just hasn't packaged it into the official release.
You just have to download the rar file, extract the contents and you should get a .lng file. Copy/move that .lng file into the languages.zip folder in the FFS install location.
It's sad not to see it in the official release :(
Is there anything it can be done to include it?
In any case, Thaaaank you very much for the info.
I'm not quite sure what Zenju's criteria are for integrating languages is. The problem I can see is that is has to be constantly maintained as text is added/removed. I don't know how he is doing it for the other languages, but it would be a huge amount of work manually
FFS translated into Catalan for version 11.14
Thanks and enjoy!
Thanks and enjoy!
Thanks xCSxXenonYou're awesome for keeping up with this! xCSxXenon, 30 Jan 2021, 21:57
I like to have GUI in my language.
It also encourages me to see the number of downloads.
FFS translated into Catalan for version 12.0
Attached below catalan.lng file in a 7z.
Thanks and enjoy!
Thanks and enjoy!
FFS translated into Catalan for version 12.1
Thanks and enjoy!
Thanks and enjoy!
Send the flag file and the Catalan translation.
good luck
good luck
I don't understand why Catalan is not in the program.
If pull requests were enabled in github it would already be done.
I translated some open source projects to Catalan language and it's so easy.
Regards.
Regards.
RAR file is not considered a convenient archive format since it need additional software like 7-zip to extract the files, unlike zip which is natively supported since Windows MEHi,
Thank you in advance Rincewind, 19 Mar 2021, 20:58
If the problem is the extension, I attach you the zip file.
Regards.
Regards.
RAR file is not considered a convenient archive format since it need additional software like 7-zip to extract the files, unlike zip which is natively supported since Windows ME harryytm, 24 Jan 2024, 05:13Hi,
FFS translated into Catalan for version 14.11
Thanks and enjoy!
Thanks and enjoy!
FFS translated into Catalan for version 14.12
Thanks and enjoy!
Thanks and enjoy!
FFS translated into Catalan for version 14.13
Thanks and enjoy!
Thanks and enjoy!
