I just started testing your product and I have a question about the behavior of the source "move detection" of files and folders.
The situation is I have two identical (synchronized) external drive volumes and I always want to keep them synchronized after making changes.
It seems if I move a folder into another folder within the source drive FFS detects the move correctly and moves all the folder's files within the target drive without re-transferring from the source. This is very effective.
But if I move files (as opposed to folders) from one folder to another within the source volume FFS would re-transmit all the relocated files from source to target and delete the old (still identical) copies. For large files this costs a lot extra time.
My question, is it a bug or a feature?
moving files vs. moving folders
This should work, too. Maybe you are testing on a FAT filesystem which only has limited support for file ids, or the file modification time changed in addition to the move?
Ah, now on NTFS it works. The first test was on FAT32 where it still doesn't work. I don't know how this makes a difference though. In no case the (moved) test file has any change.
For future reference I've added information about move detection to the manual:
https://freefilesync.org/manual.php?topic=synchronization-settings
