Errore "sync.ffs_lock"
dragonblu17
Hello. I have a problem with free file sync. Basically (I state that already use on other 3 pc) I recently bought a new PC and installed free file sync. But when I go to make a backup file, the program creates a file is in the source folder is in the destination called "sync.ffs_lock" and procedures freezes and does not go forward, and I have to manually end. What does it depend? And what should I do?
Salve a tutti. Ho un problema con free file sync. In pratica (premetto che lo uso giĆ  su altri 3 pc) ho da poco acquistato un nuovo pc e ho installato free file sync. Ma quando vado a fare la sincronizzazione dei file, il programma crea un file sia nella cartella di origine sia in quella di destinazione chiamato "sync.ffs_lock" e il proceso si blocca e non va avanti, e lo devo terminare manualmente. Da cosa dipende? E cosa devo fare?
Can you give a few more details on what is happening (observable behavior) as well as test setup (hardware, software)...
dragonblu17
I do not know if I understand what you asked me, however, use an operating system win 7 (like other pc), as hardware use an intel core i5 3.20GHz CPU, 4 GB of RAM. For now I do not know if you can serve more to solve my problem. If you need more information please ask me what you want to know precisely.
Translated with google translator.
Just to confirm: So the symptoms you are seeing is an application hang? And you believe it to be happening when writing the sync.ffs_lock file? Are you able to reproduce the hang.
dragonblu17
I apologize but I do not know if I understand what you asked me. I try to explain the problem, and describe step by step what I do and the problem that gives me. In practice I start the program, in the left column I select the folder to be synchronized in the right column I select the folder to be synchronized and updated. Then I try to do before the comparison between folders, where at the end shows me the files are in the folder to the left and to be copied in the right one. Now at this point start the synchronization and the program is now in the block (if I open the task manager, free file sync, not responding and I have to finish the process) and I create a file in any folder (both left to right) called sync. ffs_lock.
Point out that these settings are the same settings that I use on other PCs that I have. I also did other tests such as synchronizing folders on the same hard disk, synchronize folders between two external hard drives, I tried changing USB ports. The result is always the same.
I hope this will be helpful to solve my problem.
Please, if need further info, I ask you to use simple terms to simplify my translation and be able to respond more precisely to your requests.
Thanks for your help.
dragonblu17
STEP1
dragonblu17
STEP2
dragonblu17
STEP3
dragonblu17
STEP4
dragonblu17
These are the main screen of the steps that I do, hoping that you can help
Alright, thanks for the context info. Let's find out what is causing the hang:
Download the tool Process Explorer, then reproduce the hang with FFS, start ProcessExplorer, right-click on the FreeFileSync_x64.exe (or *_win32.exe if you're on 32-bit Windows), select "Create Dump" and then "full dump". Next, compress this file and send it to me via email (see FFS's about dialog). This should help me find out what FFS was doing during the hang.
dragonblu17
Sorry but I do not understand what to do. I send you attached the image after right-click on frre sync exe file. From here on, I did not understand what to do.
Thank you so much for your time and for your patience.
Thank you so much for your time and for your patience.dragonblu17
With "FreeFileSync_x64.exe" I mean the process name, *not* the installer.
dragonblu17
I hope I've got it right. I attach the file.
Thank You.
[Attachment was removed! File name: FreeFileSync_x64.rar (27189945 bytes)]
Thanks, the call stack looks normal, no indication of an error, however the active assembly instruction is the following:
vpsrlq xmm3,xmm0,34h
This sounds familiar:
viewtopic.php?t=1354
Are you on Win7 without SP1?
