As the topic says, I would like to be able to compare ONLY on file name, excluding file date and size.
It doesn't matter why, let it be known that I've ended up in this situation more than once.
[Feature request] Compare ONLY on file name
If files have different names, FFS always considers those files to be "different" (unless files have been renamed, and you use the "detect renamed files" option).
FFS always only compares files with the same name (in the same (sub-)tree location).
For identically named files (in the same (sub-)tree location), FFS needs "something" more to determine a sync action or direction. Those options are the Comparison variants, otherwise FFS can simply not determine what to do.
While it doesn't support syncing, you can at least see whether (and where) files with only the same name are present with AllDup:
Hth
Hth
Yeah, that request makes no sense... The only reason to detect only a name change, is if you renamed a file, which FFS can detect
@cv2702
Actually, "why" matters very much. Without a good description of the use-case and benefit a developer cannot evaluate the relative importance, value, and therefore priority of a new feature. With such a request, they'll likely assume it's a rare edge-case, and the request will be relegated to the dust heap of "when I run out of useful things to do"... which is "never".
(Also, for free software, saying it like that can be very... annoying to a developer. Just a heads up.)
Sorry to revive old posts but...
Here's a use case: my camera produces .jpg and .nef files (that's Nikon's RAW image file format). They have the same root name name eg. DSC_5325.jpg and DSC_5325.nef. I take a lot of pictures and want to "cull" those I don't want to keep. It would be so helpful if deleting the jpg took the nef with it.
My $0.02
My $0.02
That is something you would want added to the functionality of File Explorer or the Nikon software, not FFS though. This wouldn't even affect your use-case because the extension is part of the filename
pseudo-code:
(namepart, would return the name part of the filename, sans extension.
Windows actually uses %~nI, I think it is, to accomplish that.)
for i in (*.nef)
set base=namepart(%i)
if not exist %base%.jpg del %base%.nef
next i
I started to use FFS to sync files from my PC to my Google Drive account and on this matter is a great tool. But Google Drive has some old photos that was imported from Google Photos (I may say I have over a hundred thousand files only in Google Photos folder) and I want them to be removed if I have the original file. The thing is both size and date are different from the original file, but name is exactly the same.Yeah, that request makes no sense... The only reason to detect only a name change, is if you renamed a file, which FFS can detect xCSxXenon, 09 Feb 2020, 16:56
That's because my camera keeps the same name format as year, month, day, hour, etc etc... so it would be very useful to find files with the same name in different folders of a cloud service. There are situations when the name are exactly the same, but online services change both time and size at their convenience sometimes.
My workaround is to download both folders and let Windows compare them... but that takes a looooot of download/upload.
Now it's just going back into the realm of duplicate detection, which FFS doesn't and shouldn't do.
It's not a matter to detect duplicate photos, but to check if there's one in the cloud with the same name but different date and size, so I can choose to keep the current cloud version or switch with my hard disk version which in my case has a better resolution considering online service decrease the quality for space.Now it's just going back into the realm of duplicate detection, which FFS doesn't and shouldn't do. xCSxXenon, 01 May 2022, 14:42
Olay I could switch to a new cloud service but that's the same I could switch to another sync software. Which I think it's the best solution as I can see it's not a matter of software limitation but developer personal choice.
But thank you for interacting.
Hello to this old post.
I have a new Use case..
I had to restore a git repo, but the staging is gone for whatever reason.
Now i checked out the remote in a new folder and want to compare the old repo with the new.
Well every single file is marked as changed, even with file content due to different line endings.
Now i've changed all the file endings and now it's a new line at the end, which appreared out of nowhere.
Just a lot of hassel for a seemingly easy thing to implement in this tool.
Like "Custom compare":
Here is a list of file properties that are used to search for differences..
- File Name [1]
- File Date [ ]
- File Size [ ]
In some order so you can select whats checked first, or not checked at all.
Anyways i'm going to try AllDup.
- File Name [1]
- File Date [ ]
- File Size [ ]
I also want to have File Name only.
my use case is synchronizing music between computers and snaphosts of my music library.
The DJ softwares that I use are often altering files to add metadata and tags. I need to ignore the file modifications, but only look for missing files on either side. Full compare by size and modification time is for another workflow. I initially want to see what files are missing on either side, and start from there.
Please, allow us to look for missing files by name only within the directory structure, and ignore size & timestamp diffs. It would be a separate workflow to equalize the contents. At first, I only want to see which files are missing
Let me start to thank you all for fantastic work, you are doing with the software, it is amazing.
I also want to have File Name only too. 😊
I am working with unencrypted files locally and encrypted online. My problem is that while the filenames are exactly the same, the content and date are changed. Therefore in the sync it will replacing the same files.
Cheers
Cheers
What is you sync'd locally, then encrypted & uploaded?
So you sync from /my files/ to /my files to go to cloud/.
Then copy/encrypt from /my file to go to cloud/ to /encrypted/.
Then simply move anything that is in /encrypted/ to CLOUD.
You'll end up with (potentially) 2x the files locally but that should get what you want into your CLOUD.
I, too, would like to request a feature to compare files by file content or file size alone, ignoring the file names. My use case is I am migrating away from Google and using Google Takeout to export my data. It automatically converts Docs and Sheets to Word and Excel file types, but Takeout also truncates filenames to 47 characters. I can copy most of the non-Google-proprietary data manually via Google Drive on the desktop, but would like to use FreeFileSync to then merge all the missing .docx and .xslx files from the Takeout download into the folder structure. Unfortunately, FFS thinks all truncated files are also new (PDG, JPG, Etc.), even though they have a matching file in the target folder. FWIW, I am a donor using donation edition. Thanks for your consideration!
My case is: there's a torrent with 135 GB of files, I assume to have meny of these. I can begin downloading, then, comparing only the names, not the size, I can find the ones I'm missing.
Maybe there's other sync or compare app to do the job?
"I've seen online" that torrent clients can preallocate the space and then the files will be considered at the full size, even if they are partially downloaded. Totally doesn't work that way with a client I've NEVER used, qBittorrentMy case is: there's a torrent with 135 GB of files, I assume to have meny of these. I can begin downloading, then, comparing only the names, not the size, I can find the ones I'm missing.
Maybe there's other sync or compare app to do the job? gianniba, 11 Jul 2025, 14:48
