I’ve used FreeFileSync to back up my photos for a while to a single portable hard drive. I would now like to create a pair of alternating backups, i.e. back up to one hard drive one week and then a second the next week, then start over. Do I have to create a backup for each hard drive or can I use the same one (the original) each time?
About the only complication I can think of is making sure the path on both destination hard drives is the same, but I don’t know how FreeFileSync keeps track of what it's done with those little files it creates. I can see it looking at a file on the source and saying, didn’t I copy you last week and why are you missing in the destination backup now?
How to create alternating backups
Nope, that will work fine! The db files hold information about the local moves/renames, but that is all. As long as you get the same drive letter, or you name them the same and use the special [] formatting, it will be fine
"special [] formatting"Nope, that will work fine! The db files hold information about the local moves/renames, but that is all. As long as you get the same drive letter, or you name them the same and use the special [] formatting, it will be fine xCSxXenon, 21 Mar 2021, 14:24
I'm not sure what the pair of brackets indicates.
