Sonic Studio 3
GuidoDS
Dear FreeFileSync
Please help me out with this annoying problem:
"The file "C:\ProgramData\A-Volute\A-Volute.Nahimic\Modules\Scheduled\x64\AudioDevProps2.dll" (version 2.6.7.0) is running on your system and will cause FreeFileSync to crash.
In order to avoid crashing, either uninstall "Sonic Studio 3" or update to a newer version."
I can't find: "Sonic Studio 3" on my computer
Thank You in advance
regards
Guido
snowysakura
I have the same problem. I think it is related to a driver that Nahimic use. When I delete the related drivers and remove Nahimic, Freefilesync works. When I reinstall Nahimic the error comes back.
But in fact I never had any crushes in previous version 11.13 and there was no error so I will just use the old version at this moment.
GuidoDS
It does not help
Please fix the problem or let me use an older version
GuidoDS
Thanks this seem to help
Cheers!
This issue is still under investigation and needs feedback: viewtopic.php?t=8783#p31306
mikoy
I'm getting the same error message as in post no. 1. This stops the FFS from operating - is there a way (via command line, batch file) to force FFS 11.14 to run even when Nahimic/SS3.0 is present? (and to get rid off this warning message) Some ppl suggest they experienced no crashes whatsoever.
Can I install 11.13 over 11.14 or need to first uninstall the 11.14?
Is there an archive of Donators Edition also?
You may need to uninstall 11.14 first
Donation versions are not archived, you have to keep them
I'm getting the same error message as in post no. 1. This stops the FFS from operating - is there a way (via command line, batch file) to force FFS 11.14 to run even when Nahimic/SS3.0 is present? (and to get rid off this warning message) Some ppl suggest they experienced no crashes whatsoever. mikoy, 01 Oct 2021, 20:50
FFS 11.15 will take a different approach: viewtopic.php?t=8783#p31753
hberthol
Same error message as in post no. 1 with 13.1 version.
Thank you !
therube
What version of Sonic &/or Nahimic drivers?
Might there be an update Nahimic driver available to you?
hberthol
Nahimic Service v2.7.2.0
Sonic Studio v3.16.23.0
Windows 10 Pro 64 bits 22H2 build 19045.3636
No update available
