First, I want to say I really like FreeFileSync and use it weekly. It's been the best backup software I've tried, and I've tried a lot.
However, I have a persistent issue with slow transfers which has been affecting me since I first started using FFS several versions ago. I'm running Windows 10 and have a few different backup hard drives, all of which can easily maintain 100-130 MB/s writes over USB 3.0 - but only when copying files via Windows Explorer or another transfer program. FreeFileSync is -sometimes- significantly slower. I understand that lots of little files are slow to transfer, especially when transferring to a hard drive, but I'm talking about the sustained transfer speed of large files (such as .mp4 and .mov files). The same file transferred manually through Windows Explorer at 120 MB/s will only transfer at maybe 37 MB/s when backing up through FreeFileSync.
To get full transfer speeds in previous versions, it variously required restarting FFS, reinstalling FFS, unplugging and re-plugging the external drive, or restarting the PC. However, with the latest version 11.14, it is 100% consistent in transferring files about 4x slower than it should. Nothing I do changes the transfer speed; it is always pegged at around 37 MB/s, and of course significantly slower when transferring lots of small files. These files are all locally stored on the PC, the processor is a Ryzen 5 3600, I'm running 16GB of RAM, and these files are being backed up from a Crucial P1 1TB NVMe SSD with sustained read speeds of 2 GB/s. And again, files transferred through Windows Explorer and all other backup software I've used are copied/backed up at the full speed of whatever external backup drive is plugged in - this is an issue with FreeFileSync itself.
Does anyone know what could be causing this? Maybe a setting inside FFS?
Slow Transfers (Consistent Across Many Versions)
viewtopic.php?t=8839
viewtopic.php?t=8855
Kind of an open-end issue at the moment. Although for other users here, please make sure you search the forum before posting to cut down on duplicates and keep information consolidated.
Just throwing this one out - may be of assistance. Have you tried adjusting the Performance improvements in the comparison tab.
From FFS help - https://freefilesync.org/manual.php?topic=performance
Also from experience, I had a problem a while ago that whilst an external drive was advertised as USB3 it was in fact USB2.
Anyway, good luck but sounds like a bit of (more) frustrating trial and error.
That setting doesn't help you with local transfers. It only helps when transfers are artificially limited, not when they are simply maxed out
From other reports it seems FFS 11.14 isn't treated so favourably by Microsoft's virus scanner. I have a hunch, this slowdown could be AV-related.
As always, you can check disk activity and find interferring processes via Process Monitor: https://freefilesync.org/faq.php#trace
