Macro for Source or Destination or left or right drive?
000
I want FFS to move old files into a timestamp-folder on the drive from which they came. Is there a macro/label that I can use instead of the drive letter? That way, I can bidrectionally sync or swap sides and old files will be retained on their respective drive. Thanks.
therube
Not quite sure what you're after, but...
Variable Drive Letters
Or maybe you can do something with LABEL /MP?
It seems you may be able to use Macros.
There is really no good way of doing this while allowing the source/destination to be changed/swapped. Zenju would have to include new internal macros for source and dsetination.
