macOS Monterey
mentex
Hey,
I have a set up FFS and 2 way sync is working fine.
RTS is not working.
I get this error:
Der Befehl "/Users/Username/Documents/FreeFileSync/BatchRun.ffs_batch" ist fehlgeschlagen.
Beendigungscode 126: /bin/sh: /Users/Username/Documents/FreeFileSync/BatchRun.ffs_batch: Permission denied
Please see Attachment for my config
Thank you for your help
mentex
Does no one has an idea?
Give the volunteers here more than 10 hours maybe?
Anyhow, you should run the FFS executable with the .ffs_batch file as a parameter and see what happens. Are you logged into the user where the .ffs_batch is stored?
mentex
sorry!! sometimes I am impatient.. sorry..
I have read that i just need to drag and drop the ffs_batch to that line.
Is there anywhere a documentation how to do that on macos?
Yes it is the same user..
mentex
:) i know how to do that..
was more the question to
Oh gotcha, sorry! Here is the RTS documentation:
https://freefilesync.org/manual.php?topic=realtimesync
It autofills it with the executable first on Windows, for me
mentex
:) no problem.. on macos it is blank and then i just drag n drop the .ffs_batch to that place.. i do not know what to put in on macos..
mentex
i guess it not directly has something to do with FFS or RTS..
if i just want to run another app directly form Terminal I get:
User@MacBook ~ % /Applications/RealTimeSync.app
zsh: permission denied: /Applications/RealTimeSync.app
also e,g with VNC
User@MacBook ~ % /Applications/VNC\ Viewer.app
zsh: permission denied: /Applications/VNC Viewer.app
Edit: I guess I have to open Apps like this
open /Applications/RealTimeSync.app
mentex
ok, fixed it with:
open /Applications/FreeFileSync.app /Users/Username/Documents/FreeFileSync/BatchRun.ffs_batch
but now i cannot move files to trash like also mentioned here:
viewtopic.php?t=9099
Don't bother with writing a command line manually. Just do this:
mentex
ok, File => Open does the trick.. Any ideas why I can not delete files?
Edit: i can only see the Error when deleting files from onedrive
Edit2: Found a solution. I disabled the trash bin and delete the files immediately..
Now it looks like it is working..!
thanks
