Hello everyone. I am having trouble moving files from my external to my google drive.
When I move the same folder from the external to the same folder with the same name as google drive, when I mirror it starts deleting images into the trash can. I only want new files to be migrated and skip over any with the same name, I tried with many apps to no avail.
Need help with just moving over new files
Try using "update" sync method. Make sure your locations/paths are correct
Can you tell me how to set this up.Try using "update" sync method. Make sure your locations/paths are correct xCSxXenon, 12 Nov 2023, 16:31
